Glassed in brake line and rudder cable conduit with micro and 1 bid. Terminated rudder cable condiut at junction of proposed aluminum tubing because I did not want to penetrate the firewall until more critical aileron push-pull cables were located so that rudder cables would not interfere. Glassed in gear sockets with one bid. Put 2 bid over hole in oil cooler duct that was ground off due to nose gear fork interference.
