Installed low fuel warning switch and drain valve. Installed sump tank. Drilled hole in bottom of fuselage for access to sump drain. Cleaned up and did final glassing of slant bulkhead by strake window. Repaired the fuel tank repair on pilot side with micro and 2 bid.
