Finished removing gummy epoxy. Wing back on airplane. Scott Swing showed my how to block sand and emphasised the object was simply to remove high spots. I spread a dry black powder guide coat and finished block sanding bottom of pilot side wing and strake.
Removed tape from nose light lens and lense popped loose. The silicon caulk I used days before must have been bad because it never really set up.
