Relooked at various seat rail configurations for pilot (tall person) and copilot (short person) seat. Decided to go with my original plan which is the pilot seat moving forward without ramping up and the copilot seat using the standard configuration of ramping up as it moves forward. Mounted hard points to pilot seat with 1/4-20 screws. Marked holes in floor. Cut top layer of fiberglass to 1/2 inch outside of hardpoint lines. Dug out foam. Filled cavity with a mixture of epoxy, cabo, flox, and micro. Placed seat rail/hard point assembly into cavity. Let cure
