Decided to install the smaller (velocity standard) atkinson sight guages. Also picked up finger fuel strainers. Drilled and tapped a 1.5x1.5x.5 inch aluminum stock to a 3/8 (or 1/2) inch pipe thread for the fuel pickup. Also drilled and tapped another one with 1/4 pipe thread for the pilot side vent . Fabricated upper flange onto slant bulkhead. Dug out about a 4x4 area of foam to create a little sump for the fuel pickup. Microed and glassed the area. Glassed more bulkheads/baffles in.
Top flange onto slanted bulkhead
Sump for fuel pickup area
Hole in upper part of pilot side fuel tank for vent
