Brief Description: Cutting and installing copilot wheelwell
Finished cutting and fitting copilot wheel well to fit wheel. Made form with 1/2 inch foam for top, added release tape and glassed with 7 Bid. Built inner flange for pilot forward bulkhead. Cut fuselage to more approximate actual size of baggage compartment opening. Note the notch left for the wood block left to position upper strake correctlty.
