Brief Description: Fit wheel wells and mod wheel well
Finished shaping gear and wheel hole on Pilot side. Removed inner skin and foam from strake. Cut wheel well so as to allow for as much fuel as possible. Cut wheel well to match outboard side of tire. Could not find any regualr 1/2 inch foam so used 1/2 in scored foam to use as form over which to lay fiberglass on top of well. Scored foam did not work because it tended to fall apart when rounding edges. Will have to wait till monday and try bonding some 1/4 form together to use as mold.
