Prepared Composite Design's gold control box for installation as per the manual that came with the system. Tapped 4ea 1x1x1/4 aluminum hardpoints for 1/4"-20 bolts. Applied release tope to backside of control box and then bolted on hard points. Prepared wall of nose compartment for installation by removing inside glass and foam to the outer wall. See IMG 2347.
