Brookes Web Site
Date:  2-9-2008
Manual Reference:  6A-1.4
Brief Description:  Lower aileron torque tube
Finished up with the lower aileron torque tube today. The extra spacer washer between the pushrod end and bell crank worked good.....very smooth operation of the torque tube assembly. Reinstalled aileron trim motor. Installed aileron trim pulley. Final installation of the rear lower aileron bracket finished (image 1). The airleron trim motor can be seen in image 3.
Rear bracket looking foward
Pushrod assemble seen as white vertical rod on right.
Trim motor is dark object on left (looking aft)
Copyright © 2001-2018 Matronics. All Rights Reserved.
