Brief Description: Install MG & NG Hydraulic cylinders
Install main and nose gear hydraulic cylinders using the aluminum angles that were supplied. Made up angles for nose gear. Fabricated and installed hydraulic lines between cylinders. Prior to installation, coated floor below keel with epoxy to help protect it from hydraulic leaks
