Brief Description: Left and right bearing bracket assembly
Second attempt at completing this correctly. Riveting two thick pieces (bracket) to a thin piece (rib) can present certain problems. Mine, were obvious deformation of the rib. I used the numatx riveting gun set at 90psi and riveted it together as I normally do. On todays attempt, I lowered the air pressure to 40psi, and pre-set all of the rivets with all of the clecos in place. Making sure the bracket was snug to the rib was very important, and having all of the clecos in place proved helpful. After all rivets were pre set, I raised the pressure back to 90psi and slowly and cautiosly squeezed them all a final time.
