Brief Description: Installed both main gear legs to fuselage
Long day but managed to install both main gear legs to the fuselage. Torqued all the bolts and only have one that I am not happy with and will likely replace as I believe the nut is stripped. Otherwise the install is complete. Very small openings and area to work so it took a long time to properly install all the bolts. Needed to buy an angled socket wrench at Home Depot to complete the install.
