Brief Description: Fit wings and temporarily installed them
Spencer came to hanger for a few hours to help install and remove the wings. Difficult to do at first, as I needed to file down the spar blocks and also the flanges on each side of the channel where the spars are inserted. After doing that, both spar pins were able to be installed. The left pin is very tight and needed a lot of effort to remove.
Borrowed tension measuring tool from Martin Fessels.
