Brent Connelly - N913BC
Date:  6-10-2012
Number of Hours:  2.50
Manual Reference:  44A-02 to 44A-03
Brief Description:  Autopilot servo assemblies
Fabricated the two pitch and roll servo assembly sections. Also attached the molex connectors to one of the servos . Seven pins in all, and then bolted the roll servo to the aft end of the fuselage. Torqued the bolts and was pleased with my work. Then re-read the manual and saw that Loctite 242 was called for instead of just torquing the bolts. Will have to source the Loctite as I don't have this one on hand.
Tapping one of the assembly aluminum tubes
Pitch and Roll Servo Assemby
Roll Servo installed
