Brief Description: Prepared and Clecoed Side Skins to Fuselage
Moved fuselage off table, onto sawhorses, in order to have room to work on the side skins. Primed and riveted the two F-1202L gussets to the bulkhead channels. Cut out openings in side skins and then clecoed both skins to the fuselage. Will clamp the skins tighter to the fuselage next and then match drill the Longerons before deburring and priming everything.
