Brief Description: Installed Stall Warning Sub-Assembly and wiring fo
Assembled the stall warning assembly and installed it on left wing. Will check fit with temporary skin install tomorrow, but rest of installation went well.
Per recent posts on VansAirforce site, decided to add an extra 18 guage and 22 guage wire from the wing terminal block all the way to the wing tip. This should allow the new panel to control the stobes and nav lights separately, and the 22 guage wire I expect will be cross wired to the right wing to syncronize the strobes. Easier to remove later than add it. Will have to order more wire to similarly complete the right wing
