Brent Connelly - N913BC
Date:  5-1-2013
Number of Hours:  1.50
Brief Description:  Installed chain hoist in garage
Installed the 1 ton chain hoist that arrived mail order from Home Depot. It is relatively inexpensive and with about ten dollars of chain from the local home depot I installed it tonight. Its attached to the overhead loft that I have in the garage. The loft is well bolted to the ceiling and since I am only lifting a few hundred pounds (Rotax is only 160lbs at this point) it should work great for the hanging of the engine this weekend.
1 Ton chain hoist from Home Depot
Hung from loft
Hung from loft
Partially lifted engine
