Brief Description: Began installing interior kit in order to do weigh
Removed gascolator bowl to inspect. Found some very small metal particles from the fuel system. Cleaned and reinstalled. Had difficulty with one of the screws but was able to install and add safety wire. Removed safety wire from oil cooler so lower cowl can be installed
Removed fuel tank and cleaned surfaces in bagage compartment. Began to install baggage compartment interior kit.
