Brent Connelly - N913BC
Date:  9-22-2013
Number of Hours:  3.00
Manual Reference:  30-03
Brief Description:  Trimmed flapperons and wing skins
Had help yesterday morning to remove both wings. Went ahead today and trimmed the flapperons and lower wing skins so that they all fit the fuselage better. The SB that added doublers to the gear attachment/side skins made the fit to the wings to tight. Hopefully when I reinstall the wings, the fit will be better and the flapperons won't be touching some of the wing rivets.
Also took the opportunity to slightly widen the wing spar openings as each time I install and remove the wings, the spar rubs on the sides of the opening.
Updated Skyview to ver 7.0 and also loaded the latest FAA database. Probably a little premature but each time I do something on Skyview I get a little more knowledable & confident with it.
