Brief Description: Updated S/W and other misc steps
Updated Skyview with FAA files and began to calibrate the system. All very intuitive. Added HEX code for transponder and recorded skyview serial number to use to get MAP license code from Dynon.
Marked flapperons for trimming (they are rubbing on side skin rivets)
Adjusted trip tabs to better align both sides. Still not entirely flush and will need to work on this some more.
Fixed spar pin reed switches.
Set up hoses for engine oil purging. Will do that next.
