Brief Description: Corrected connector wiring for the pulse lighting
Checked the wing root and fuselage wiring to confirm what connector needed to be moved in order to get the main light pulse option to work. Decided to move the connector on the wing itself. Added a new connector to the place just beside the steady light connector that aligned with the fuselage connector. Wasn't able to test it until the wings are reinstalled later, but it should work correctly now.
