Brent Connelly - N913BC
Date:  8-9-2013
Number of Hours:  3.50
Manual Reference:  32-09 to 32-10
Brief Description:  Matched drilled flaperon torque tubes
Installed wings and match drilled torque tubes with Spencer's help. Removed wings and torque tubes and arms. Began match drilled the torque arms with the drill press and #12 drill bit.
When wings were on plane, tested the lights. All worked expect the main light did not pulse in the pulse mode. Will fix later.
