Per response from Scott at Van's, fabricated a 0.125 inch propeller spacer out of aluminum stock ordred from Aircraft Spruce. Primed and installed it onto propeller hub and torqued AN16A bolts also obtained from Aircraft Spruce. Excellent fit. Should give ample space between spinner and cowl.
Fabricated custom propeller spacer per reponse from Vans.
