Brief Description: Epoxy/floxed cooling and interface ducts to cowl
Epoxy floxed cooling duct and interface duct to lower cowl. Christine helped put pieces together. Epoxy hardened really fast in the heat wave we are having. In fact, several times the flox mixture simply hardened in the container before I could apply it to the aircraft. Needed to make up several different smaller batches.
Fully floxed cooling duct and cowl installed to aircraft to set up
Spinner plate is very close to cowls. Will need to check into this.
