Brent Connelly - N913BC
Date:  5-21-2013
Number of Hours:  2.50
Manual Reference:  48-01 to 48-06
Brief Description:  Completed most of muffler install
Followed all the steps to install the muffler. Applied Loctite heavy duty anti-seize to the ball joints. Torqued the nuts on the pipes but had to remove them later when I was adjusted the fit to better fit the cowl which I had to temporarily install. Need to to a little sanding of the opening on the cowl to fit the exhaust pipe. Re-torqued the nuts. Applied the RTV sealant to the springs without having to remove each one. Only have the temp probes to install next.
