Moved aircraft to other side of garage and moved around table and other parts in shop getting ready for engine mounting.
Spencer and I mounted and bolted the engine to the aircraft. Was not too difficult, but I needed to adjust the straps I was using on the engine as the ones I had in place were blocking the access to the bolts. Will need to get a 9/16" crows foot in order to torque the upper bolts correctly, but was able to torque the lower ones per plans.
