Brief Description: Began Stiffener Retrofit install
Began working on the firewall stiffener this evening. Removed gascolator from firewall and drilled out some rivets. Match drilled, countersunk, cut and deburred the spacer. Riveted it to the 1204 stiffener and match drilled the piece to the firewall. Ended by priming the part and will finish deburring and then rivet the firewall next. Side stiffeners look like a more difficult install as some tightly installed rivets need to be removed
