Brief Description: Installed chain hoist in garage
Installed the 1 ton chain hoist that arrived mail order from Home Depot. It is relatively inexpensive and with about ten dollars of chain from the local home depot I installed it tonight. Its attached to the overhead loft that I have in the garage. The loft is well bolted to the ceiling and since I am only lifting a few hundred pounds (Rotax is only 160lbs at this point) it should work great for the hanging of the engine this weekend.
