Brief Description: Installed WH-RV12 Ignition Harness to modules
Even before installing the engine to the firewall, decided to work ahead and added the igniton harness wires back into the module plugs. Sure seems easier to do this way than after hanging the engine which is planned later this week.
Fed the wire around the back of the engine and placed it behind two different cushion clamps. Added several zip ties.
