Brent Connelly - N913BC
Date:  4-20-2013
Number of Hours:  1.25
Manual Reference:  46-08
Brief Description:  Installed Manifolds and attached ignition module
Worked on other small engines today so only has a little time for the Rotax. Attached the manifolds and torqued all the M6 screws. Also attached the ignition module and needed to go back to my pictures pre-removal to make sure I oriented all the brackets ect... the correct way.
