Brief Description: Trim speed adjustment and began working on Skyview
Purchased a new charger as the one I was using seems to be a low amp version and takes a long time to top up the battery. Spencer helped me adjust the trim speed and then time it for a full range deflection. After several adjustments we got it to 24 sec. (target was 25 so I'm fine with that). In order to reach the adjustment screw on the control module, we needed to remove the Skyview screen from the panel and also remove all four screws off the control module.
After reinstalling the screen and control module I began to work on the other control module adjustments. I seemed to be having a grounding problem with the jacks on the passenger side and needed to access the wiring in order to fix. I'll eventuall find a similar problem on the pilot side.
