Brent Connelly - N913BC
Date:  4-8-2013
Number of Hours:  2.75
Manual Reference:  46-04 to 46-05
Brief Description:  Continued to work on engine
Cut off one of the starter lugs with hacksaw per plans. Rotated the small bracket that holds the ignition module in order to gain better access to the engine. Then began trimming and fitting the FF-1207 cooling shroud to top of the engine. Will evidently be a tedious process to sand, fit, mark, remove and re-sand. Did for a while and made some progress but will need another night for sure.
Removed starter lug
Removed starter lug
Rotated ignition module bracket
Began to fit the cooling shroud to engine
