Installed the Dynon GPS antenna per the instructions. Found that the wires leaving the bottom center of the antenna would not pass cleanly through the large hold in the mounting bracket or antenna shelf. So I decided to enlarge the hole in in both places in order to allow the wires to pass through the parts without being bent squeezed or bent over.
Inserted the pins into a 9 pin plug and installed this into the control module per the plans.
Cleaned up work area, did some touch up painting and got ready for next section. Will tackle the ADHRS install next.
Enlarged hole on right to allow antenna wire to pass through unobstructed
