Brief Description: Riveted brackets & skin doublers to fuselage
Continued working on SB today. Riveted the 1204U-B and -T brackets to the center channel using the CherryMax rivets. Difficult to do in close quarters with the manual rivet puller. Needed to cut out two of them poorly set and replace. Then worked on riveting the four 1270 A & D side skin doublers. Used LP4-3, CherryMax and CS-4-4 rivets for these pieces. Only messed up a few. Overall, pleased with results but clearly took longer than one expected.
