Brief Description: Continued to work on main wheel pants
Worked on fitting halves together some more and really like the fit. Opened the lower opening wider per the instructions. Temporarily fit the side brackets and they seemed reasonable good. On one side the holes just barely line up for the screws. Should be able to fit them as I have to drill the holes for the screws later and I'll be sure to line them up with the nutplates.
Match drilled the halves together and that went well. Then measured (several times) before cutting out the openings for the gear legs. Seems to have gone well. Will know for sure later then I'll install them.
