Brief Description: Fit and installed rudder cables
Attached v-stab and rudder in order to fit the rudder cables. Christine helped feed the cables through the tailcone. Fabricated the four parts in the first picture needed to attach the cables to the rudder petal assembly. Difficult to install the hardware as the working space is very tight. Temporarily installed and will finish later.
Rudder cables attached - need to tidy up wire in this space
