Brent Connelly - N913BC
RV-12
Match drilled tabs to fairing
Attached fairing top and bottom to the tailcone and match drilled the F-1294C tabs. Drilled screw holes as well. Began counter sinking the nutplate rivet holes.
RV-12 Home
1337
06 - Vert. Stabil
07 - Rudder
08 - Anti-Servo Tab
09 - Stabilator
10 - Tailcone
11 - Emp Attachment
12 - Emp Fairings
13 - Spar Assembly
13 Spar Assembly
14 - Rear spar, tub
15 - Wing Ribs
16 - Stall Warning
17 - Wing Skins
18 - Flaperon
20 - Ctr Section Bul
21 - Mid Fuse Ribs &
22 - Fwd Lower Fuse
23 - Side Skins
24 - Rollover Struct
25 - Tailcone Attach
26 - Seat Backs
27 - Rudder Petals &
28 - Fuel System
29 - Fwd Up. Fuselag
30 - Wing Attachment
31A - Wing Electrica
31B - Fuselage Wire
32 - Flight Controls
33 - Miscellanea
34 Canopy Install
35 Landing Gr. Engin
36 - Gear/Leg Fairin
37 - Fuel Tank
38 - Cowling
40 - Lighting
41 - Interior Panel
42C - Skyview D1000
42D - Skyview Update
42F - ACK E-04 ELT
44A - Autopilot Serv
45A - FW FWD Wiring
46 - Engine Installa
47 - Spinner Propell
48 - Exhaust System
49 - Cooling System
50 - Engine Controls
51A - Placards
52 - Towbar
53 - Skyview ADS-B
54 - Stiffener Retro
Finishing
Hanger
Int.Options/Paint
Production Acceptanc
SB 12-11-09
SB 13-04-05
SB 13-08-08
Workshop
