Brent Connelly - N913BC
Date:  9-23-2012
Number of Hours:  3.00
Manual Reference:  38-06
Brief Description:  Countersinking then hinge riveting to cowls
Finished remaining countersinking of all the cowl edges where hinges were to be riveted. Then began riveting all the hinges. Only needed to remove two rivets that were not good enough. Needed to use an AN426-4 rivet in one hold after drilling out the AN426-3 rivet. Replacement is hardly noticable.
Upper cowl.
Upper cowl.
Replace one rivet with a slightly larger one.
