Brent Connelly - N913BC
Date:  9-13-2012
Number of Hours:  1.50
Manual Reference:  38-02 to 38-03
Brief Description:  Cowl trimming and work on hinge pins
Finished trimming some of the openings on the bottom of the lower cowl. Went rather fast using the dremel tool and cutting close as possible to the trim lines. Sanded them and all openings look very good.
Match drilled two of the holes for the cowl as instructed. Marked the others which I assume will be match drilled later.
Began working on the all the hinges for the cowl attachment. Organized myself and moved forward measuring, bending and cutting all the hinge pins I will need. Will carefully mark and cut the actual hinges I'll need, next time.
Trimmed parts of bottom cowl
Drilled and marked forward flange of upper cowl
Began cutting and fitting hinge pins
