Brent Connelly - N913BC
Date:  9-1-2012
Number of Hours:  3.75
Manual Reference:  34-02 to 34-04
Brief Description:  Installed canopy onto fuselage
Installed canopy frame to the fuselage as directed. Need to add two 1/4" washers to right side and one on left to complete clear the fuselage when opening the frame. Installed the gas struts.
Clamped the frame to the fuselage as best I could and then began to flute and match drilled the angles to the frame itself. Fairly pleased with the fit in the end.
