Assembled several parts of the fuel tank with fuel tank sealant and various rivet types.
Fwd bulkhead attached to the T-1201 Main Tank. T-1205 tank bracket and inboard and outboard clips also attached. Installed both the fuel fittings to the main tank. And finally installed the two baffle parts into the tank.
Not easy to work with this tank sealant material. Everything it touches, it spreads onto. I ran a little low towards the end but I'll have to go back and add some additional sealant to some corners and rivet heads to ensure a perfect seal.
