Brief Description: Installed nose wheel to aircraft
Tapped the two 5/16" holes in the nose fork and added stop screws. Completed installation of the nose wheel to the aircraft. Did my best to adjust the nut holding the assembly to the arm for the 26lbs side force. Might be a little light, but can adjust later if the nose wheel is too loose. Will have to order some addtional cotter pins as spares.
