Brief Description: Installed brake clamp & prepared parts
Installed cushion clamp for the brake lines. Needed to reverse orientation as the lines are aft of the wiring since I installed them after the wiring bundles were installed. Should not be an issue.
Began to prep/prime the parts for section 32-03 (flap control parts)
