Brief Description: Installed Rudder Petals into Fuselage
Finally installed rudder petals to fuselage, delaying this until most of wiring was completed. Not an easy task with the fuselage on its side, but probably easier than if it was sitting upright. Will still need to atttach the wire flanges around the rudder petal assembly and attach more of the brake fluid lines to the assembly and the brake reservoir.
