Brent Connelly - N913BC
Date:  7-6-2012
Number of Hours:  3.50
Manual Reference:  31B-12 to 31B-13
Brief Description:  Worked on control sticks.
Finally managed to finally get a string fed through both control sticks by using a vaccum cleaner. Worked amazingly fast and eay. Should have been recommended in the plans as we waisted time yesterday trying to feed various different wires through the sticks. Managed to feed the PTT wires and another backup string thorough the sticks.
One of the two brass bushings would not allow the AN4 bolt to go through it not matter what filing I did. Searched several local h/w stores and could not locate a reamer. So I finally ordered one from Brown Tools. Puttered around and prepared and primed the ELT bracket. Will likely work on more wiring tomorrow.
Feeding PTT Wires through control sticks.
ELT bracket getting painted.
