Installed two CPU fans. Routed the WH-00046 wire bundle through the panel base and several clamps & bushings into the central part of fuselage. Attached some wires to the molex connector for the fuel transducer. Also installed the Aux Music Jack and the smaller molex connectors. Routed some additional wires from the bundle towards the wings.
WH-00046 wire bundle. Would be a much bigger job to install each wire independently.
Panel base and two CPU fans
Part of wire bundle still needs to be installed in fuselage
