Brief Description: Panel Attach Strips and Began Map Box
Finished riveted all the nutplates to the attach strips and then riveted both attach strips to the upper fuselage skin. Only need to drill out a few AN426 rivets here and there.
Began working on all the parts for the Map Box. Trial fitted it together and match drilled a few places. Decided to countersink all the attach holes in all three panel sections at the same time to make sure they were consistently done. Seems relatively consistent across them. Deburred and primed the Map Box section only as I am still waiting for next shipment of primer. Will need to make some decision about the panel paint relatively soon. Inside box will be painted with the grey interior paint I've sued elsewhere inside the fuelage.
Attach strip installed along the top perimeter of the panel area
Attach strips flush riveted to the upper fuselage skin
