Brent Connelly - N913BC
Date:  3-22-2012
Number of Hours:  3.50
Manual Reference:  21-16
Brief Description:  Prepared and clecoed bottom skin to fuselage
Long but productive evening doing all the prep work on the bottom skin ending up with it being clecoed to the fuselage structure. Lots of deburing which took time and used blue painter's tape to isolate the places on the bottom surface that needed to be primed. (see second picture). All the ten triangle shaped doublers are to be attached to the outside surface of the bottom skin so all those places needed priming. Also primed the bottom edge of both corner skin sections where the bottom skin is riveted. Pleased with results.
Primed inside surface of bottom skin
Nutplated installed on five access ports
Initial clecoing of skin to fuselage
