Brent Connelly - N913BC
Date:  3-9-2012
Number of Hours:  3.25
Manual Reference:  21-03 to 21-04
Brief Description:  Riveted Mixer Arm & Began Seat Ribs
Decided to drill out and re-rivet some of the rivets for the bearing assemblies I had finished yesterday. The LP rivets were installed the opposite way that the instructions called for. Probably would be solid and a non-issue, but probably is not good enough in aircraft construction. So I removed four of the accessible ones from each side and reinstalled the rivets in the correct orientation.
Finished riveting the Pully Bracket and the Flapperon Mixer Assembly. Attached bolts/washers and torqued the final bolt. Assembly seems well constructed but I still can't figure out how it works. Will need to read ahead.
Began deburring and preparing the seat belt attach lugs and the seat ribs themselves. Got most of the way through them tonight. Will finish tomorrow.
Pully bracket and flapperon assembly
Eight seat ribs to prep
