Brent Connelly - N913BC
Date:  11-28-2011
Number of Hours:  3.00
Manual Reference:  40-09 to 40-10
Brief Description:  Finished installing wing tip lights
Spent the evening attaching both the wing tip extensions and also the brackets and lights. Most difficult part was working with the fuel tank sealant per the instructions. I was very careful to not make a mess of it and I'm very pleased with the clean look.
Finally tested both lights and they look great. Did have a problem with one of the hex screws that holds the light onto the bracket (unfortunately inserted it on an angle and it was partially stripped) Will need to order a replacement.
Right wing tip extension being installed
Left nav light
Left nav light
Left strobe
Left strobe
